Palladium
Palladium is a conducting material in the same family as platinum, but less expensive. They have the same resistivity.
All values except melting point are assumed to be at 25 degrees C, and may vary dramatically over temperature.
Formula or Composition: Pd
Bulk Resistivity: 10.7 μΩ-cm
Bulk Resistivity: 1.07E-7  Ω-cm
Bulk Conductivity: 9.42E6 S/m
Temperature Coefficient of Resistivity (TCR): 3800 ppm/°C
Mass Density: 12 gr/cc
Heat Capacity: 247.7 J/kg/°C
Thermal Conductivity (k): 75.2 W/m°C
Temperature Coefficient of Expansion (TCE): 11.8 ppm/°C
Melting Point, °C: 1552 °C
Melting Point, °F: 2826 °F
