Microwave Switches
Here we will discuss both solid-state and mechanical switches, including design considerations as well as laboratory switch operation. If you are looking for RF switches, click here.
Here is a clickable outline for our Microwaves101 web pages on microwave switches:
Faking 3-port switch data from two two-port measurements (new for August 2016)
Microwaves101 switch FET model (new for February 2016)
Adding temperature coefficients to measured switch S-parameters (new for December 2015)
Chalcogenide switches
Solid-state switches
MMIC versus hybrid
Switch device models
Comparison of PIN diodes and FETs for switching
Two-terminals versus three terminals
Switching figure of merit (FOM)
DC dissipation of switch elements
Switching speed
Geometry lesson
Switch FETs
Meandered gate switch FETs
Resonating off-capacitance in switch FETs
Power handling considerations for switches
On-state
Off-state
Driver considerations
PIN diode driver examples
FET driver examples
Positive voltage biasing for FET switches
Ferrite switches
Mechanical switches
Reed-type coax switches
Waveguide switches
MEMS switches
The Riddle of MEMS
Switch design
SPST switch (switch arm) design
Shunt versus series elements
SPDT switch and multi-throw switch design
Designing high-speed switches
Designing for high power handling
MMIC switch design example
Important consideration for designing with shunt switch elements
RF switch considerations and terminology
There are many things you must consider when you design or buy a microwave switch. Let's try to list all of them all here, before we get into details below:
Reflective versus non-reflective (terminated) switches
A reflective switch does not provide a "good" fifty-ohm termination to the arm(s) that are switched off. A non-reflective switch provides terminations, and is a more complicated network.
Terminations: do the isolated ports of your switch need to present 50 ohms to your system? Can they handle the intended power?
Bandwidth: not just the upper frequency of a switch is limited by the technology you choose. PIN diode switches don't switch down to DC, but FETs do. Capacitive MEMS switches also have a high-pass response.
Insertion loss: will a dB or two of switch loss kill your system performance?
Isolation: how much RF signal can your switch leak before you are in trouble?
Power handling: is your switch going to be positioned on the output of a power amplifier?
Driver requirements: the driver circuits for PIN diode switches and FET switches are quite different, since the former requires a DC current while the latter requires a DC voltage, usually negative polarity.
Switching speed: how fast does your switch need to change state?
Expected lifetime: how many switching cycles do you expect your switch to handle? This is no concern for solid-state switches, but a big consideration for mechanical and MEMS switches.
Size: can you fit a connectorized switch, or do you need to look at a chip or surface mount IC switch?
Content moved here.
