Microwave Printed Circuit Boards
Click here to go to our main page on microwave packaging
Click here to go to our page on microwave circuit card assemblies
Click here to go to a page on hints for RF PWBs
Click here to go to our page on FR-4
Click here to learn how to extract DK and DF from transmission line measurements
Click here to go to our page on cost versus performance of soft substrates (new for September 2017)
New for October 2017: here's a new website that exists only to manage a database of all PCB (PWB) manufacturers.
Check out PCBDirectory.com
It's about time we added some content this important topic. This is gonna take some time, but it will go a lot faster if we get some audience participation like we did from Mike and Greg!
Here's a tip from Microwaves101 reader Mike on how to fix a board with a short circuit:
I recently ran across a problem and solution that you may find valuable enough to post on your great page. My company which I will keep anonymous recently had to do a commutator board. When the boards were received from the manufacturer, one of them had a slight problem. One of the RF traces of the switch output was grounding out. A call to the manufacturer lead us to this diagnosis: when the board was processed, a sliver of metal from the ground plane was left still in contact with the RF trace. The company told us a quick fix for this, without having to have them build a new board for us was to ground the ground plane and send a high amount of current through the RF trace. This current would cause the sliver that is grounding out to burn up and there would be no more problems with the trace. Low and behold it worked and we didn't have to wait for a new board and then have to mount all new components to it! From now on, we are spending the extra cash and having all the boards tested by the company before they are shipped to us.
This is still a jumble of topics, sorry!
PWBs for microwaves are fabricated similar to PWBs for digital and "low frequency" applications. However, in microwaves we often are restricted to two-sided boards instead of multilayer boards. Instead of ceramic substrates with gold metalization, lower-cost "soft" substrates with copper metalization are process.
Fabricating PWBs
Here is a list of steps that are done to create a microwave PWB:
1. Mask-making
2. Material selection
3. Cleaning
Thorough cleaning is essential to the etching process. Cleaning is accomplished in a combination of solvent bath, rinsing with deionized water and or alcohol, blow drying and baking.
4. Apply photo-resist
5. Imaging: here the mask is used to expose the photo-resist
6. Etching
7. Drill
8. De-smear
9. Metalize
10. Solder mask
11. Finish metalization
12. Stencil
Ounces of copper
Copper for PWBs is often specified in "ounces". This arcane term actually originates from how many ounces of copper would be rolled out per square-foot. Half-ounce copper is 0.7 mils (18 microns), one ounce copper is 1.4 mils (36 microns), and two once copper is 2.8 mils (71 microns) thick. Thanks to Ricardo for correcting our math in converting from mils to microns!
Some definitions that are related to PWB processing:
dry film photo-resist
negative photo-resist
positive photo-resist
blind via
through hole
Undercutting
Etch factor
This is the nominal difference between the mask feature and the etched features.
Hey, PWB designers, help us out with some content!
