Click here to go to our main page on microwave connectors
Click here to go to our page on connector torque
New for June 2023. The TK connector is kind of an oddball dating back to at least the 1970s. It is a 50-ohm interface and works to 18 GHz and possibly higher. It has PTFE dielectric that splits across the male-female interface, as shown below. There is also a compressible O-ring gasket that should help protect the interface from liquids seeping in. It is fully qualified for military applications and the interface is covered by MIL-STD-348, look for Figure 329-1 (which we shamelessly cribbed for this page). The TK hex nut is 9/16 and it requires 12-15 inch-lb. of torque, 50% greater than SMA connectors (5/16 nut, 8-12 inch-lb.) Pro-tip: if you don't torque a TK connector properly you can expect a frequency suck-out around X-band!
Here's a photo of female and male TK connectors.
Below is a photo of a TK-female to SMA-female adapter.
And here is a TK-male to SMA female adapter.
Where else but Microwaves101 will you find photos of TK connectors? Answer: nowhere. Try doing a Google search.
