Phase delay formula derivation
Click here to go to our main page on time delay
Click here to go to our page on TDUs
New for February 2022.  Someone aske us this question: How is the equation for time delay, which is frequency divided by unwrapped tranmission phase, derived?
Propagation constant of a wave along a transmission line is described exactly as:
γ=√(Z^′ Y^′ )=√((R′+jωL′)(G′+jωC′) )=α+jβ
Where α is the attenuation constant and β is the phase constant
For near-lossless transmission line, (R’<<ωL’ and  G’ << ωC’ ):
α≈R^′/2∙√(C^′/L^′ )+G^′/2∙√(L^′/C^′ )=R′/(2Z_0 )+(G′Z_0)/2 (Nepers/meter)
β≈ω√(L^′ C^′ )  (radians/second)
Wavelength is distance where phase changes by 2π radians:
λ=2π/β (meters)
Phase velocity is defined as wavelength multiplied by frequency:
v_p=λf=2π/β f=ω/β=ω/(ω√(L^′ C^′ ))=1/√(L^′ C^′ ) (meters/second)
Time delay is defined as length of line divided by phase velocity:
•  Time delay=l/v_p  (seconds)
Noting that phase velocity and time delay are:
  v_p=2π/β f (m/s)  Time delay=l/v_p  (seconds)
By substitution:
    Time delay=l/v_p =βl/2πf   (seconds)
 “Electrical Length” at fixed frequency is  related to βl: [2]
  EL=βl×360/2π (degrees)
Replacing  βl with EL in time delay equation:
Time delay=(EL 2π/360)/2πf=EL/(f×360)
Noting that the unwrapped phase of a transmission line is:
  AngU(S(2,1))=-EL
Time delay, a.k.a. phase delay, is expressed as:
  Time delay=(-AngU(S(2,1)))/(f×360)
One problem is that nwrapped phase angle is often ambiguous, especially if low frequency data are missing, like in a bandpass filter. YOu have to put on your Sherlock Holmes detective hat to extract the correct value! We'll explian that later...
