Packaging, assembly, and interconnects
Click here to learn about hermeticity
Click here to learn about epoxy used in electronics
Click here to go to a page on fiducial markers
This will serve as our main page from which we will branch out and cover some packaging topics in-depth. Our apologies in advance, we know that this material is not well covered yet. If anyone has any comments on the definitions below, or material to submit (especially photos), send them!
This topic deserves to be huge, but without some help from engineers like you it will take some time to construct. If you want fame and fortune, send us some material to add, like Nameless Insider from New Jersey did!
Microwave packaging is often broken into two broad categories: modules (often called hybrids) and circuit card assemblies. The intent of the two approaches is best summarized as this:
Use a hybrid module if you want bulletproof reliability,
Use a circuit card assembly if you want cheap.
Below are further definitions that will show the distinctions between various categories of microwave packaging. One of the big distinctions between various packaging methods is whether or not hermeticity is provided; hermetic sealing of active devices in inert atmosphere extends reliability and is often a requirement for military systems.
Multi-chip modules: these combine two or more chips (integrated circuits) into a more complex circuit. Often an MCM is a non-hermetic package. And often, the distinction between MCM and Hybrid is blurred.
Hybrid modules: hybrids combine chips (discrete or monolithic), interconnect substrates, and passives (resistors, inductors and capacitors) into one module. Hybrid construction almost exclusively implies that hermeticity is provided. Fedoras are used to get signals into/out of the housing yet maintain hermeticity. Often, the housing is fabricated from low-expansion alloys. Lids are hermetically welded on with laser or seam sealers.
Microwave Integrated Circuit (MIC): here a circuit is constructed from discrete devices (transistors) into a larger circuit such as an amplifier. MIC refers more to a method of construction, than a type of packaging (such as hybrid module). The "classic" MIC circuit is a balanced amplifier which contains two identical transistors, a pair of Lange couplers, and suitable blocking capacitors and bias elements such as resistors and inductors. An MIC circuit can often be replaced with an MMIC (monolithic microwave integrated circuit). Back in the day when MMICs were a new technology, supporters of MIC said that no matter what, they could always wrestle better performance from a device than a MMIC designer could. Today, MIC construction has almost been completely replaced with MMICs, because increased functionality is only possible though massive integration.
Chip-and wire: chip and wire refers to a method of construction, which is the basis for MIC circuits and hybrid modules alike.
Thin-film:
Thick film:
Microwave circuit card assemblies:
Printed wiring boards form the "substrate" for CCAs. Here's a page that offers PWB hints.
Cofired ceramics come in two flavors: low temperature (LTCC) and high temperature (HTCC).
Reliability:
Electrostatic discharge: no matter how you package electronics, ESD is something to consider.
Relevant books for microwave packaging
Advanced Electronic Packaging, by Richard K. Ulrich and William D. Brown is an encyclopedia effort with a treasure-trove of information on various material's parameters, different interconnect schemes, design, fabrication and assembly of hardware, not just microwave (which we consider a plus!) Look for it soon on our book page.
If you are developing prototype modules in a lab, chances are you will take a lot of short cuts and not worry about half the stuff on this page. But if you intend to design something for production, you should learn as much as you can about production packaging processes.
Some possible future topics:
  • Advanced interconnects such as flip-chip
  • Near-hermetic packaging
