Click here to go to our main page on LNAs
Click here to go to our main page on receivers
Click here to learn about noise parameters
What makes a good low noise device? Ideally, you want to optimizeall noise parameters: GammaOpt should be close to the conjugate match at your operating frequencies. RN should be as large as possible to provide a "soft" fall-off as your matching network moves away from Gamma_opt.
Choice of device type: GaAs pHEMT is better than SiGe HBT
Geometry: Multiple gate fingers lower the gate resistance. Certain peripheries may have hold teh advantage of gamma opt for noise figure being closer to conjugate match.
Dissipation: large devices cause more heat raising channel temperature.
Bias point: Usually a low voltage just pass the knee of teh curve is going to give the lowest NFmin, with current well below Class A.
Intrininsic properties: if your process has any gate leakage at all, it will show up in noise figure.
Here's a wite paper from NXP that provides much more detail on LNA design.
